qtVlm 5.10.7 not working on raspberry pi
- tdml02r
il y a 4 ans 8 mois #1117
par tdml02r
qtVlm 5.10.7 not working on raspberry pi a été créé par tdml02r
trying to run qtVlm 5.10.7 on raspberry pi but getting the following error:
./qtVlm
Aborted
i have tried to install libxcb-xinerama0 but it is already the latest version (1.14-3)
any ideas what's wrong?
thanks
Tom
./qtVlm
Aborted
thanks
Tom
il y a 4 ans 8 mois #1118
Réponse de maitai sur le sujet qtVlm 5.10.7 not working on raspberry pi
First of all we are now running 5.10.9-p1, please update.
Also have a look at documentation page 9.
--Philippe.
--Philippe.
- Remerciements reçus 2
il y a 4 ans 8 mois #1119
par oxygen77
Réponse de oxygen77 sur le sujet qtVlm 5.10.7 not working on raspberry pi
Also, if updating is not enough, launch qtVlm from command line after inputing this:
And put the output here
Code:
export QT_DEBUG_PLUGINS=1
- tdml02r
il y a 4 ans 8 mois #1120
par tdml02r
Réponse de tdml02r sur le sujet qtVlm 5.10.7 not working on raspberry pi
thank you for the fast responses.
upgraded to 5.10.9-p1 and tried everything on page 9 of the manual : still same issue.
debug output:
QFactoryLoader::QFactoryLoader() checking directory path "/home/pi/Downloads/qtVlm/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqlinuxfb.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqlinuxfb.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
"MetaData": {
"Keys": [
"linuxfb"
"archreq": 0,
"className": "QLinuxFbIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("linuxfb")
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqminimal.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"archreq": 0,
"className": "QMinimalIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqoffscreen.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"archreq": 0,
"className": "QOffscreenIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/home/pi/Downloads/qtVlm/platforms/libqxcb.so"
Found metadata in lib /home/pi/Downloads/qtVlm/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"archreq": 0,
"className": "QXcbIntegrationPlugin",
"debug": false,
"version": 331008
Got keys from plugin meta data ("xcb")
Cannot load library /home/pi/Downloads/qtVlm/platforms/libqxcb.so: (libxcb-util.so.0: cannot open shared object file: No such file or directory)
QLibraryPrivate::loadPlugin failed on "/home/pi/Downloads/qtVlm/platforms/libqxcb.so" : "Cannot load library /home/pi/Downloads/qtVlm/platforms/libqxcb.so: (libxcb-util.so.0: cannot open shared object file: No such file or directory)"
Aborted
Thanks
Tom
debug output:
"MetaData": {
"Keys": [
"linuxfb"
"archreq": 0,
"debug": false,
"version": 331008
"MetaData": {
"Keys": [
"minimal"
"archreq": 0,
"debug": false,
"version": 331008
"MetaData": {
"Keys": [
"offscreen"
"archreq": 0,
"debug": false,
"version": 331008
"MetaData": {
"Keys": [
"xcb"
"archreq": 0,
"debug": false,
"version": 331008
Aborted
Thanks
Tom
il y a 4 ans 8 mois #1121
par oxygen77
I guess that you are on a recent version of raspbian ?
Can you try :
- go in: /usr/lib/arm-linux-gnueabihf
- do: ln -s libxcb-util.so.1 libxcb-util.so.0
Launch again qtvlm
Can you try :
Launch again qtvlm
- tdml02r
il y a 4 ans 8 mois #1122
par tdml02r
Yes I’m using the latest version (bullseye)
That worked, thanks very much
