Cannot install qtVlm on macOS Catalina 10.15.2
- thericksteruk
il y a 6 ans 8 mois #117
par thericksteruk
Cannot install qtVlm on macOS Catalina 10.15.2 a été créé par thericksteruk
hi I am trying to install the new version 5.9.5-p1 and I cannot open the program up after moving the main folder from the dmg to applications, all I get is an error. It says:
"qtVlm" can't be opened because Apple cannot check it for malicious software.
This software needs to be updated. Contact the developer for more information.
I am running macOS Catalina 10.15.2
any help would be gratefully appreciated.
Richard
Richard
il y a 6 ans 8 mois #118
Réponse de maitai sur le sujet Cannot install qtVlm on macOS Catalina 10.15.2
Hi Richard,
Apple did a great job with Catalina indeed...
The solution is to locate qtVlm.app via the finder and to try to run it from there.
If it does not work then again with the finder you should right-click, choose "open a terminal" (the last option), and type:
sudo xattr -rc .
(note the point at the end)
sudo xattr -rc .
- thericksteruk
il y a 6 ans 8 mois #119
par thericksteruk
Réponse de thericksteruk sur le sujet Cannot install qtVlm on macOS Catalina 10.15.2
Hi maitai,
Thanks for that it worked a treat.
Many thanks,
Richard
Many thanks,
Richard
- labezinchristian
il y a 6 ans 8 mois #120
par labezinchristian
Réponse de labezinchristian sur le sujet Cannot install qtVlm on macOS Catalina 10.15.2
Hi Philippe,
The fix worked pretty well ... until I downloaded the -p1 release and now dear Catalina insults me in the following terms :
christian@pc12 ~ % sudo xattr -rc .
Password:
xattr: [Errno 1] Operation not permitted: './.wine/dosdevices/e::'
xattr: No such file: ./.wine/dosdevices/d:
xattr: No such file: ./.wine/dosdevices/d::
Any idea ?
Christian
Password:
Any idea ?
Christian
il y a 6 ans 8 mois #121
Seems to me that you are not inside qtVlm directory. You should find it with finder and open a terminal from there (right-click, last command).
- labezinchristian
il y a 6 ans 8 mois #122
Oops !!!
correct !! so sorry for this unnecessary solicitation
Christian
Christian
Temps de génération de la page : 0.173 secondes
