Cannot install qtVlm on macOS Catalina 10.15.2
il y a 6 ans 8 mois #123
Réponse de maitai sur le sujet Cannot install qtVlm on macOS Catalina 10.15.2
No problem
- zeehaen
il y a 6 ans 7 mois #154
par zeehaen
Réponse de zeehaen sur le sujet Cannot install qtVlm on macOS Catalina 10.15.2
Hi Maitai,
I recently bought the full IOS-version and qtvlm works like a charm on the ipad, but I experience exactly the same problems as mentioned in this topic installing QtVlm on my macbook. I also tried to type in the command you mentioned, but after 'entering' that command I am requested for a password in the next sentence. I tried every apple pasword I could imagine, but it doesn't work. What to do next, can you help me me?
regards
Alex
regards
Alex
il y a 6 ans 7 mois #155
Hi Alex
The password needed is the same as the one you use for instance when there is a MacOS update.
Maybe the sudo command is not compulsory. Once inside a terminal window into qtVlm directory just try:
xattr -rc .
Regards
xattr -rc .
Regards
- MichelleWhy
il y a 6 ans 7 mois #156
par MichelleWhy
Réponse de MichelleWhy sur le sujet Cannot install qtVlm on macOS Catalina 10.15.2
- zeehaen
il y a 6 ans 7 mois #157
par zeehaen
Thank you for your fast respons Philippe! I tried your last solution and no password is being asked now and I am able to run qtVlm now!!! NICE!!!!
il y a 6 ans 7 mois - il y a 6 ans 7 mois #158
@MichelleWhy :
As said before Catalina is a pain...
You should do the following:
From Finder locate the folder where you installed qtVlm (don't go inside it, stay in the parent folder). Right click on the folder and choose "open a terminal' (the last option). Then type
xattr -rc .
(note the point at the end, very important)
Then you should be able to run qtVlm
xattr -rc .
