- Remerciements reçus 37
bluetooth stability
il y a 6 ans 4 mois #265
Réponse de maitai sur le sujet bluetooth stability
Hello again,
I had another user with similar problems a few weeks ago, and finally we discovered that he had "Scan for nearby devices" switched on on his Android device. Once he switches that off all was back to normal.
Can you please try that?
- mawer
il y a 6 ans 4 mois #266
par mawer
Réponse de mawer sur le sujet bluetooth stability
Hello Philippe,
To check the wifi I need access to the boat (using my vyacht router); It`s not possible at the moment (lock down; harbour closed); will try it as soon as possible. "Scan for nearby devices" is switched on; I will change this and try again; I`m a bit busy today but might check it late afternoont; will report later. That would be an easy solution !
I really appreciate your support !
Martin
Martin
- mawer
il y a 6 ans 4 mois #268
par mawer
Hello Philippe,
switching off "scan nearby devices" did not change the bluetooth performance; screen refreshing time in map mode is about 40 seconds but variable (e.g. after zoom in or out); refreshing time in start mode is exactly 60 seconds all the time; it looks like the companion waits for some missing data and after one minute it stops that and refreshes the screen ? Qtvlm (panasonic CF20) gets only the data from the internal GPS (SOG/position) because it`s not connected to the NMEA network (I am at home because of the lock down and have the time to "play around"). Is the missing nmea connection the problem ?
The first connection between companion and qtvlm is always a bit of roulette; it tooks up to several minutes until the symbols turn from red to green.
I tried a Galaxy S9 (android 9) and could not establish any connection; the smartphone was connected properly to the panasonic but companion was not "turning green".
Regards
Martin
Regards
Martin
il y a 6 ans 4 mois #269
Just to make sure what is the frequency rate of your NMEA input (configurable in the main dashboard) ?
Regards,
Regards,
- mawer
il y a 6 ans 4 mois #270
par mawer
Hello Philippe,
My internal GPS is a u-blox 8 chip and the baud rate is 9600; I make the ajustments in the u-center; in qtvlm I have no idea where to ajust the baud rate of the internal gps. The serial ports in qtvlm are 38400 for incoming nmea (but I`m not connected to the nmea network !).
Regards
Martin
Regards
Martin
il y a 6 ans 4 mois #271
Hi Martin,
If you click in the middle of the microboard on the upper right corner (with the boat icon, start NMEA etc) you will get the regular board, there is a NMEA tab, where you can tune the boat refresh frequency (max is 1 Hz, regardless of the baud rate or other), and this is also the rate of sending to Companion.
Temps de génération de la page : 0.154 secondes
